Old 01-13-2008, 03:46 AM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
Default Manifold Hose Nipple removal
Does anyone have any tips on trying to remove a hose nipple from an aluminum manifold.. Or is it just hold you breath and twist!!!!
Carl
Old 01-13-2008, 03:58 AM
Default Re: Manifold Hose Nipple removal
I would heat the aluminum up well before removal. It will expand and make removal easier and less damaging.
Jason
Old 01-13-2008, 04:12 AM
Is there any danger of melting with propane
Carl
Old 01-13-2008, 04:19 AM
I use Mapp gas and have never had a problem. I think Mapp Gas is hotter.
Jason
Old 01-13-2008, 04:53 AM
Ill give it a try!!!!!!!!!!!!!!!!&^%&%**%^$
Carl
Old 01-13-2008, 05:05 AM
John Brown's Avatar
FWIW, sometimes tightening a pipe fitting first will expand the hole making loosening it easier.
John Brown
Old 01-13-2008, 05:23 AM
VintageMusclecar's Avatar
You need some canning parafin (wax). If you don't have any handy, you should be able to find it at just about any grocery store.
Carefully heat the fitting with MAP gas or propane, just don't get carried away.
Once it's hot, apply some canning parafin to the base of the fitting where it threads into the manifold. The heat will cause the parafin to melt and wick itself down into the threads where it will act as a lubricant to ease dis-assembly. Might take a couple of trys, but it works.
Eric
Old 01-13-2008, 05:30 AM
Ill Give it a try, It looks like who ever installed the Nipple (long long ago ) Many have used some form of brown colored compound.
Maybe form a gasket ???????????????
Carl
Old 01-13-2008, 05:44 AM
Ooooooo.....that's nasty stuff to work with if it's the one that sets up hard.
Good luck!
Eric
Old 01-13-2008, 05:45 AM
Do ya think the heat would break it down???????????
Carl
