Old 01-29-2024, 12:53 AM
A12pilot's Avatar
A12pilot A12pilot is offline
Thanks, Steve! I’m probably going to get side tracked with a couple more projects shortly, but progress will continue!
Cheers
Dave
Old 01-29-2024, 12:56 PM
TimG TimG is offline
It looks great, Dave.....
Old 01-29-2024, 02:09 PM
----As usual, just bitchin, Dave!....Bill S
Old 03-24-2024, 10:24 AM
A12pilot's Avatar
Final bodywork starts today! After the 100 mile test drive, I've decided on what needs to be changed and will start ordering those parts.
I'm hoping June/ July for final paint. Been chatting with a few upholstery shops too and one is really excited about doing my car, but it's up in Connecticut. I'd rather have the car local to me (or at least in a short flight range) to check on things when needed.
Attachment 258466
More to come!!
Cheers
Dave
The Following 17 Users Say Thank You to A12pilot For This Useful Post:
427 (03-24-2024), 67 Nova Boy (05-10-2024), 69M22Z (03-26-2024), big gear head (03-24-2024), Dave Rifkin (03-24-2024), dykstra (03-26-2024), L78_Nova (03-25-2024), L_e_e (03-24-2024), markinnaples (03-24-2024), mssl72 (03-25-2024), olredalert (03-24-2024), PeteLeathersac (03-24-2024), SS427 (03-25-2024), Tenney (03-24-2024), Woj (03-26-2024), YenkoYS-199Stinger (03-25-2024), Z282NV (03-24-2024)
  #955
Old 03-24-2024, 10:14 PM
Z282NV's Avatar
Z282NV Z282NV is offline
So what needs to be changed Dave? It looks perfect to me.
Joe
1969 Camaro
Old 03-25-2024, 12:46 AM
A12pilot's Avatar
Hi Joe,
I wasn’t happy with the transmission shifter placement, so I’m swapping out tail shafts on the T5 to the Camaro version which will put the shifter exactly where it needs to be. Those parts are headed this way. Parking brake linkage and cable routing changed. Electric window regulators to allow me to make the door panel correct with the larger lower pockets. Changing cooling fans to swirl style (straight blades sound like a F5 tornado approaching!) Floor plenum ducts for the footwell heater/vents. Inner Door latches moved/new mechanism. Higher rate coils for the back. Rear convertible top well modified a bit for more top clearance. Hardtop needs to be massaged a bit on the forward edge. Drip troughs in the hood area trunk area, and door weather stripping retainer channel installed. I think that’s about it!
Dave
The Following 6 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (05-10-2024), dykstra (03-26-2024), olredalert (03-25-2024), RPOLS3 (03-25-2024), Woj (03-26-2024), Z282NV (03-25-2024)
  #957
Old 03-25-2024, 12:51 AM
Are all those running changes going to be noted in the next edition of the AIM ?
Your speedometer gear location might change when you change the tail housing on the transmission. BW made different main shafts for those transmissions for the different gear locations. I don't know which shaft you have and if the gear location will change or not, but just giving you a heads up so you won't be surprised.
Old 03-25-2024, 01:52 AM
Z282NV's Avatar
Originally Posted by A12pilot View Post
Hi Joe,
Dave
That is very smart of you to get some
miles on it before making the final touches like interior and paint. I can't wait to see it done like the rest of us following you on this journey.
Joe
1969 Camaro
The Following User Says Thank You to Z282NV For This Useful Post:
Woj (03-26-2024)
  #960
Old 05-08-2024, 11:13 AM
dykstra's Avatar
dykstra dykstra is offline
Any updates Super Dave??
Dave Dykstra
NCRS#66003
you. – Jeremy Clarkson.
Dykstra Motorsports
markinnaples (05-08-2024)
