Old 09-17-2008, 07:46 PM
TDW TDW is offline
Default GM part number help
A friend is cleaning out his body shop. He has some NOS GM parts. Can someone tell me what they are? Thanks.
GR 10.7--7731200
3914771
3914773
4654540
4587866
5938319...lens
400463...union
400461-91E7...fuel line
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-18-2008, 06:11 PM
Default Re: GM part number help
I recognize #7731200 as 1968-69 Camaro inner door belt moulding,(i.e.window fuzzy),they used on the assembly line when equipped w/std. trim NOT custom trim.
If nobody else replies to these,I'll try & look em up when I get home later tonight..
Old 09-18-2008, 06:39 PM
TDW TDW is offline
Thanks Rick. I think some of it is stainless trim for a 55 Chev, but I can't find the numbers anywhere on the net.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 09-19-2008, 10:20 PM
TDW TDW is offline
OK..Thanks anyway.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 09-25-2008, 06:01 AM
I found these
GR 10.7--7731200 WEATHERSTRIP, FRT DOOR INNER W/STD TRIM (Window Fuzzie) as above
3914771 group 1.266 68 Camaro (exc. R.S.) ....... GRILLE ASSY., upper (Note 4) ...................... NOTE 4 Requires 6-121753 washers, 6-120375 nuts.
3914773 1.266 68 Camaro (exc. R.S.) ....... GRILLE ASSY., lower (Note 5) ...................... NOTE 5 Requires 8-3843001 nut assy.
Old 09-25-2008, 07:54 PM
TDW TDW is offline
Thank you very much. I appreciate it.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 09-26-2008, 01:13 AM
803140 ?
Old 09-26-2008, 07:00 AM
366298 ? 6272785
Old 03-23-2012, 06:40 PM
frenchyee frenchyee is offline
Hi i would be interested in buying the parts 7731200 if interested please let me know [email protected] or text me 289 253 4967
Thanks Pierre
Old 03-23-2012, 06:42 PM
Thanks Pierre
