Old 12-28-2008, 11:44 PM
Donutblue Donutblue is offline
Default 1987 Grand National T- Tops $12500.00
Extremely clean straight 1987 Buick Grand National / (WE2) with (G80) code Posi rear end. This car has been garaged kept and covered. It has never been raced, nor has it been beat on. It’s tuned with boost set at minimum spec. No rust or rot anywhere. Body is Super straight with no dings. All body lines line up perfectly. It was stripped down to bare metal and professionally repainted about 3 years ago due aged worn paint. The paint is very flat, smooth, shines incredible, and looks like glass. It has been driven about 600 miles in the past two summers, presently about 81k. I have never driven it in the rain or winter.
Interior is close to mint with original radio concert sound and working power antenna. Runs and drives beautiful and sounds very strong with no unusual noises. No smoking no leaks! Turbo Spools nicely and goes down the road straight, with no pulling, shaking, or vibrations. Very quick with firm accurate shifts. . . ENGINE IS ALL STOCK. Due to the age of these cars I have done the recommended maintenance upgrades for this relatively stock GN. (Listed below). I do have all original parts that will go along with the car. You can drive this car safely anywhere…
Here is a list of NEW ITEMS...
BF GOODRICH TIRES ALL AROUND
BILSTEIN SHOCKS
FRONT UPPER AND REAR CONTROL ARM BUSHINGS
SWAY BAR LINKS
IDLER ARM
COMPLETE TRANSMISSION OVERHAUL WITH ART CARR SHIFT KIT
NEW D5 TOURQUE CONVERTER 2200 STALL (FACTORY)
BILLET SERVO & HARDENED INPUT SHAFT
ALTERNATOR
4 CORE RADIATOR
BATTERY
INJECTORS LUCUS #30 (CONSIDERED TO BE FACTORY REPLACEMENTS)
ACCUFAB AFPR
RJC POWER PLATE
RJC BOOST VALVE / SET @ 15PSI
WALBRO FUEL PUMP / HOT WIRED
MAGNAFLOW STAINLESS STEEL DUAL EXHAUST
T-TOP SEALS
INTERCOOLER (CLEANED AND FLUSHED)
REAR MAIN SEAL
ENGINE MOUNTS
TURBO TWEAK STREET CHIP (93 OCTANE)
COLD AC / CONVERTED R134
NEW BRAKES ALL AROUND
ADJUSTED WHEEL BEARINGS
VDO BOOST GAUGE
ALL FLUIDS FLUSHED AND REPLACED.
VACUME HOSES
SCANMASTER SCAN TOOL
ALUMINUM COLD AIR INTAKE /K&N FILTER
COIL PACK / PLUGS / WIRES / PCV VALVE /FUEL FILTER
SERPENTINE BELT
TIE ROD ENDS
O2 SENSOR
ADJUSTABLE WASTEGATE
TURBO
HEATER CORE
160 THERMOSTAT
That’s it…. You wont be disappointed with this purchase.
Very sharp GN, and hard to find in this shape.
This is the original advertisement when I purchased this car this past January, I have driven it about 600 miles since CALL George 914-438-7185 [email protected] -- Poughquag, NY 12570 -----12,500.
http://s64.photobucket.com/albums/h1...ue/Buick%20GN/
"I never think of the future. It comes soon enough." - Albert Einstein
