Old 01-08-2009, 12:57 AM
COPO CARTEL COPO CARTEL is offline
Default Caliper
Need to find a 69 Camaro front drivers side caliper I think the part # / casting # is 5463633, please no turds. Thanks
Drive it ...Like you STOLE it !!
Old 01-08-2009, 08:39 PM
Default Re: Caliper
Is this casting # correct Thanks Doug
Old 01-09-2009, 03:51 AM
Default Re: Caliper
Doug
This is one of the few components where the part # cast is not the same as the part # called out in the books or on the original boxes.
I called a friend who has still has the original front end on his 69 Camaro,and he relayed the casting numbers on both left & right calipers were #5463633 w/158 & 159 cast as their dates.
I believe Chevrolet recognizes these as #5469122-Lefthand & #5469123-Righthand and those would've appeared on their original boxes.
Both 1969 Camaro & Nova w/ft.disc and 1970 Nova w/ft.disc,used these calipers.
His car also has the original factory dust shields,#5463496-Lefthand & #5463497-Righthand.
I hope that helps some..
Old 01-09-2009, 05:01 PM
Default Re: Caliper
Thank you Rick for the response.
