I need the following parts for my 69Z. Build date is the 3rd week of January:
● reproduction brake booster and master cylinder cap ● incorrect exhaust manifolds and smog components, plug wire heat shields also missing ● carburetor is too early for the build date of the car, 7B1 ● incorrect coil ● generic replacement voltage regulator ● 1968 reproduction wood steering wheel ● incorrect intake manifold bolts ● engine lift hooks missing ● left and right side intake manifold wire loom holders missing ● incorrect oil cap ● hood drilled for hood pins ● generic replacement water pump ● ZL-2 option added to car, reproduction air cleaner ● valve cover bolts and misc hardware is incorrect ● hood pad installed upside down, incorrect clips ● flat bead window fuzzies, very bad ● antenna base bezel is incorrect or missing ● door jams do not receive GM decals ● generic replacement fuel pump and mounting bolts ● incorrect Firestone tires and FW rally wheels ● upper cowl area painted black, should be body color ● car should not have trunk mat, does not have deluxe interior ● generic replacement rear leaf springs ● no T-bolts in rear axle mounting ● incorrect rear axle lower shock plates and hardware ● gauges added to car, no clock in dash cluster ● seats are bolted on top of carpet, not correct ● fuel tank straps should be painted semi gloss black and should NOT have rubber insulators under them ● incorrect starter motor ● brake booster hose bracket is missing Thanks, John 215-945-1984
http://i708.photobucket.com/albums/w...t/DSC00005.jpg |
