Old 02-04-2009, 10:15 PM
beater68427 beater68427 is offline
Default 1967 Chevelle SS 396 350hp convert
1967 Chevelle SS 350hp with Docs, This is a nice driver the paint is good a couple years old Base Clear, interior is good has a small crack in dash pad that just decided it was time. White top 2yrs old only seen the sun a couple times, I just built a new engine has 530 miles on it, The car had a 66 short block in it, but had the original heads, I found a correct intake and carb. The engine is RESTAMP date coded engine, I did rent the correct stamps and fixture when I did it. Price $42,000.00 you can email me [email protected] or call 801-726-0455
1967 Chevelle convertible SS 396 350 hp
Deepwater Blue exterior
Black interior
White top non power
AM radio works fine
Blinker tach
12 Bolt posi 3:31 original 410 car
4speed console
New wheels tires 17inch (not fond of them) also a few burnouts
New brakes and wheel cylinders 530 miles ago
New U joints 530 miles ago
Engine Specs
1967 396 .040 over size tank cleaned block flashing also ground out of lifter valley new cam bearings surfaced..
Crankshaft NOS GM standard
Rods resized with ARP bolts
Pistons Forged speed-pro 11:1
Small flat tapet cam Have to get specs from my shop
Double roller chain
M77HV pump
Heads have all new stainless valves new springs locks and retainers, I cut them for pc seals .531
surfaced.
Balanced
Brass freeze plugs
Billet flywheel
Centerforce clutch
Pertronics ignition
The car is not perfect but a very nice driver, serious people no trades 801-726-0455 Thanks Jeff
