Old 02-07-2009, 09:40 PM
turbojet427 turbojet427 is offline
Default Hurst Shifter
What is the difference between an original 1969 Camaro big block hurst shifter and a small block hurst shifter? How do you tell the difference?
Old 02-07-2009, 11:00 PM
farone farone is offline
Default Re: Hurst Shifter
Both shifters are the same, but the linkage and rods are different....
What do I know ????? I didn't write any books....
Old 02-07-2009, 11:20 PM
anybody have pics?
Old 02-07-2009, 11:28 PM
Plowman's Avatar
Plowman Plowman is offline
On the same muncie trans? I think the handle might be different because the motor and trans are located one inch to the right for BBC.
Old 02-08-2009, 12:42 AM
m22mike's Avatar
m22mike m22mike is offline
Same handle # 5325, and a #3138 body, unless someone knows of a differant handle.
Matt, what do you want a picture of ?
Mike
Old 02-08-2009, 12:49 AM
RPOL88 RPOL88 is offline
Here is a big block shifter I recently sold.
http://cgi.ebay.com/ebaymotors/ws/eB...m=300275865199
Old 02-08-2009, 01:05 AM
I got an original 69 camaro Hurst Shifter, I seen where there is a difference b/t the big block one and small block one. I was trying to figure out what I got.
Old 02-09-2009, 12:56 AM
Unreal Unreal is offline
I believe the shifter and handle are exactly the same for bb vs. sb. The difference is the mounting bracket as shown in RPOL88's auction, and the rods. Since the bb shifter is about 1/2" further away from the tranny than the sb one, the rods are bent just a little differently.
Old 02-09-2009, 03:01 AM
Thanks I think I got a set of BB rods and linkages. Are the rods any thicker?
Old 02-09-2009, 03:51 AM
Here's what I think I know. SB and BB rods are the same diameter. The correct BB rods are numbered. SB are not. Both sets are longer than the aftermarket Hurst rods. Rev. is 9" 1st. & 2nd. is 14 3/4" 3&4 is 17 1/2".3&4 uses a fine thread. (3/8ths.-24). The factory 9 hole & the BB mounting brackets lower the position of the shifter on the transmission. Both brackets have an elongated hole for the bottom bolt that allows you to pivot the shifter for your desired location. Let me know if I need to be corrected. Thanks, Tom.
