Old 02-28-2009, 07:02 PM
Guest
Posts: n/a
Default Door handles Part # 3064225 /3064224
Does any one know what these door handles fit? I could not find the part number listed.
Thank you.
Old 02-28-2009, 07:56 PM
Default Re: Door handles Part # 3064225 /3064224
These fit 68-75 Nova
'10.527 68-75 Nova 3064225 Left Front (Less Button)'
'10.527 68-75 Nova 3064224 Right Front (Less Button)'
as of the 1983 62-75 parts book.
Would look good on my Nova....
Old 02-28-2009, 08:27 PM
They're correct for what Greg stated,but only if it's a 4 door.
1968-75 Nova four door only,Front & Rear.
1964-67 Chevelle two door only.
1967-69 Camaro two door only obviously.
These actually superseded the earlier released door handles #9706522RH & #9706523LH,originally used during the late 60's to early 1970's.
Your's were initially released later on during the 1975-6 model run.
Old 03-01-2009, 08:43 PM
Guest
Posts: n/a
Thank you for the information.
Old 03-03-2009, 11:36 PM
Mr70;
These were interchangeable. The difference is the button shaft. The handles do have a slight difference in shape. Nothing huge. In 1973 5716870/1 replaced 9706522/3 and 5716871 was replaced by 97065223.
In 1972 they listed 9706522/3 for all applications. There is also obvious lack of mention of 4 door. So they should work for either front or rear.
As of 1983 3064224/5 was listed for all.
One of these day I would love to get a set of each and compare them side by side.
Interesting to note that 5716870/1 was 67-68 Camaro and 9706522/3 was list as 69 Camaro. Yet later one work for all.
Greg
