Old 03-06-2009, 05:26 AM
Default Flint and Tonawanda?
Were the LT-1 engines for the 1970 Z/28 and later years assembled (stamped) in both Flint and Tonawanda?
Thanks,
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 03-06-2009, 07:51 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Default Re: Flint and Tonawanda?
The only ones I have seen have been done in Flint.
Old 03-06-2009, 05:27 PM
Stated earlier from JohnZ.
[i]"Tonawanda had two completely separate V-8 lines - one complete system (machining and assembly) for small-blocks, and one for big-blocks.
ALL big-blocks were built at Tonawanda.However,on the small-block line,they only built hydraulic-lifter engines,and didn't have the added machining stations in the small-block cylinder head line to add the unshrouding cut in the chamber wall required for 2.02" intake valves.
<u>All small-blocks with solid lifters i.e. LT-1 (and the few hydraulic-lifter engines that used 2.02" valves, like the L-79) were built at Flint V-8, which had the unshrouding-cut stations in their cylinder head lines."</u>
Old 03-07-2009, 11:45 AM
Kurt S Kurt S is offline
And who else would know this except for John......
What a resource for the hobby!
Kurt S - CRG
