Old 03-09-2009, 10:30 AM
SS69chevelle SS69chevelle is offline
Default Wanted BBC early roller cam/lifters
I am looking for a BBC cam and lifters that required the block to have a guide groove cut to run the lifters. I currently have a 427 block that has this modification and I would like to try and find a cam and lifters to install rather than having to bush the lifter bores. I have been told that these were early rollers before the link bars. If anyone has any info on these please contact me. Thanks Andy
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 03-09-2009, 08:10 PM
Chevy454 Chevy454 is offline
Default Re: Wanted BBC early roller cam/lifters
I may be mistaken, and someone will *gladly* correct me if I'm wrong, but I always thought grooving the lifter bores was simply another aid @ rebuild time to get more oil to the lifters, and not necessarily a necessity...so it wouldn't be cam/lifter specific, right? The early big blocks required a grooved rear journal on the cam to oil the lifters, and the groove can be added to any cam...been there, done that!
Old 03-09-2009, 09:09 PM
beater68427 beater68427 is offline
This would be the process for oiling grooves, there were some very early roller's that require a receiver groove. The lifters today might be very hard to come by.
Old 03-09-2009, 10:12 PM
Interesting...I'd always heard about grooving lifter bores, but just never had 'cause to.
Old 03-10-2009, 08:20 AM
Thanks for the info guys. The odd thing is the lifter bores are grooved on the top side of each bore from top to bottom. It is also a considerable groove and I'm concerned about oil pressuse if they aren't bushed or the grooves filled. Honestly, I don't expect to find any lifters but thought I would take a chance and put the info request out to some of the best forums to see if anyone had knowledge to share. I continually learn alot from the forums here and at Team Chevelle. thanks again for the comments. Andy
Andy
Team Chevelle #3135
ACES #08305
