Old 03-16-2009, 04:12 AM
sg1747 sg1747 is offline
Default Problem with cowl induction hood
Does anyone have problems with their cowl induction solenoid working and then not working. I have replaced the wiring harness, solenoid and the flapper. It all works when attached to a battery but when I connect it to the hood I can put a test light in the wire and it works but when I hook the solenoid up to the cowl it doesn't work. Am I having a ground prolem? Should I run a ground from the solenoid to the hood?
