Old 05-20-2009, 04:33 PM
lbnaz lbnaz is offline
Yenko Premier Member
Default Wanted 66 327/275hp Nova short block.
Looking for a Nova short block 327/275 hp 65-67. Thanks, Larry.
Old 05-21-2009, 04:03 PM
speed speed is offline
Default Re: Wanted 66 327/275hp Nova short block.
I have a 67 327 275 long block out of a caprice. I am in PA
Old 05-21-2009, 04:54 PM
I'd expect it's one of the Nova specific blocks w/ the recessed oil filter that's req'd...'362' casting or?.
Old 05-22-2009, 06:49 AM
Hello, Thanks. I have 327's out the wazzo. I need a 362 or a 721 block the way I understand it with the recessed oil filter. Maybe someone can educate me. Do I need a recessed block in a 66 with a PG transmission and factory exhaust manifolds. I'm told that the recessed block is for 4 speed Z bar clearance only which I do not have. Thanks, Larry.
Old 05-28-2009, 01:11 AM
COPO_Anders COPO_Anders is offline
You don´t need the Nova-block for clearance using a PG transmission and factory exhaust manifolds. I hade a 1969 350 block with a PG and factory manifolds in my -66.
The 4-speed Z-bar needs the Nova-block because of the mounting hole down by the oilpan.
Anders Stålklint.
After selling my COPO 9561 I´m now a "postman" with the main project being a 1966 327 2 dr sedan Chevy II.
Old 05-28-2009, 07:32 AM
kwhizz kwhizz is offline
Anders is correct........."Z" bar clearance only......But...I used a normal block in my 66 when it had a 4 speed in it......I made my own "Z" bar and had no troubles, just had to use a short oil filter
Ken
Old 05-28-2009, 05:22 PM
beater68427 beater68427 is offline
I have one carb to pan 67 but it's pricy.
