Old 05-20-2009, 07:40 PM
SS427's Avatar
SS427 SS427 is offline
Default Water jacket filled Big Block?
I have a 512 block that I would like to use in a very limited street engine build up. The block was filled up to the bottom of the water pump inlets with a solid material (forget what it is called) as many racers in the day did. My question is will this give me any potential problems on a limited street (stock) engine with an adequate stock cooling system. Seems like I remember using blocks like this back in my teenage years with no issues.
Rick Nelson
Old 05-20-2009, 08:28 PM
beater68427 beater68427 is offline
Default Re: Water jacket filled Big Block?
Most of the heat is in the top of the engine, I would think you would be fine your oil temp is going to be a little higher, but the only real way to fid out is give it a burn see what happens.
Old 05-21-2009, 12:19 AM
I have a ZL1 with the same issue. Its called block filler or hardblok.
Jason
Old 05-21-2009, 05:16 PM
plumL78 plumL78 is offline
I have a 66 396 block that is filled with hard block. Its punched out to a 427 bore (.155)10.0 comp. Its never been over 190. Just last week end at the ocean city. Md. cruise we sat in a tons of traffic and never got hot. I don't think it gets past 180 in normal driving
Old 05-21-2009, 05:40 PM
------Rick,,,Red Alerts big motor was hard-blocked half way up because it was a hundred over. With the electric water pump switch on you couldnt get that "14 to 1" compression motor to overheat. As was stated above the heat is primarily in the top of the motor.........Bill S
Old 05-21-2009, 06:50 PM
SS427's Avatar
Thanks for the responses guys. I had figured it would be ok but wanted to get a little input from anyone that has dealt with it before. I appreciate the input and feel more comfortable using it now.
Rick Nelson
Old 05-21-2009, 06:57 PM
sYc sYc is offline
As Bill said, Red Alert runs a filled block, high compression, a stock water pump, and have had no heating problems.
Well, just when I do a long burnout and toss the belt.
Tom Clary
Old 05-29-2009, 03:41 PM
Mr BB Chevy's Avatar
Mr BB Chevy Mr BB Chevy is offline
i now a few people that have filled block in pro street cars. hydraulic cement(block hardener)filled blocks for strenth.
i hate that. ;-)
in this video, i tossed the belt and the light came on while doing my burnout, so i shut the car off while waiting to make a pass.
tossed belt run, notice track guy looking under car. lol
1 of 311
Acrobat Signs
Acrobat Tactical
