Old 05-29-2009, 05:04 AM
P.J. P.J. is offline
Default SW heat gauge
I am trying to get my vintage SW heat gauge to work in my chevelle.I hooked it up to the Gm heat switch and It does not work. I grounded the gauge and the needle went right to the end ,so I know that the gauge works.Does this gauge need
a special heat switch???
PJ
Old 05-29-2009, 07:39 AM
John Brown's Avatar
Default Re: SW heat gauge
It needs a S-W 362 series sender.
What size pipe thread do you need, or what is the diameter of the hole, in inches? I have some new old stock S-W 362-AJ senders that are 3/8 pipe threads, or about 5/8 or so inches in diameter for the threads.
John Brown
Old 05-29-2009, 07:49 PM
Thanks John
the dia. of the pipe thread is 830 thousands of an inch at the cylinder head head and it is 14 threads per inch.
If necessary I can step it up from 3/8 pipe to 1/2 pipe if it is the correct sending unit for the gauge.
Let me know what you want for it
Thanks
Pj
Old 05-29-2009, 08:38 PM
John Brown's Avatar
Peter, the 1/2" variety is available from
http://www.glen-l.com/inboard-hdw/sw-gauges.html
You need part number 90-975. Don't worry about it saying 100-240 degrees, because the Deluxe gauges just leave off the number 60 down at the bottom of the gauge. I didn't know what size hole you had, but I'd rather see you get the correct sender instead of having to use an adapter. Just glad I could help out.
John Brown
Old 05-29-2009, 08:51 PM
I have a bunch of NOS ones. The part numbers are 362AA, 362AH, and 363E. Let me know what you need.
Jason
Old 05-29-2009, 08:58 PM
Old 05-29-2009, 09:03 PM
John Brown's Avatar
He needs a 362-AH. They're brass and brass won't weld itself to an aluminum intake.
John Brown
Old 05-29-2009, 09:05 PM
What is the difference between the 2? They look the same externally except one looks to have a steel body and the other is brass.
Jason
Old 05-29-2009, 09:11 PM
John Brown's Avatar
The difference in the numbers is brass vs. steel body. The boat versions are brass, but steel welds it self to aluminum through corrosion, so I wouldn't use the steel ones for that reason. If you have a cast iron intake it wouldn't matter though.
John Brown
Old 05-29-2009, 09:13 PM
Thanks John, you really know your SW. P.J., if you need one let me know. If anyone else is looking for one there are plenty to go around.
Jason
Jason
