Old 06-25-2009, 12:25 AM
Dog427435's Avatar
Dog427435 Dog427435 is offline
Default Need advise on repair of Hildebrand knock offs
I noticed a noise / feeling coming from the left rear wheel. Removing the wheel and inspecting the area I found 1 of the pins had sheared off. The rear portion had fallen through and was gone. Further inspection found 4 of the other pins will turn in either direction, but not tighten or loosen, and the other pin does not move at all.
I have not gotten the car on a lift yet and its tough to see how this assembly comes off laying on my back - anyone familiar with these knock off assembly's?
My question is - are these pins supposed to be set firmly or not? Does it matter that these other pins turn and could that be a contributing factor in why this one pin failed?
Any idea's as to where to locate the proper parts for this set-up, or can I just check my local supply house for a similar piece?
Thanks
Old 06-25-2009, 05:35 PM
Default Re: Need advise on repair of Hildebrand knock offs
I expect it's Halibrand stuff you have...here's a link if any help.?
http://www.halibrand.com/
If the above no good perhaps the Vintage racing and Cobra crowd can lead you to parts but if not can you thread the holes to a good quality wheel stud size and use them as your pins?.
Maybe added sleeves w/ tolerances enough to rotate if this is necessary?.
Cool stuff Dog...what are you running this setup on?.
I like real cars best...the REAL real ones!
Old 06-26-2009, 09:52 PM
Dog427435's Avatar
[b]Thanks Pete!
Maybe if I properly spelled halibrand I would have had better luck with my search!
These are on my summer loaner -
Old 06-27-2009, 02:39 AM
x  Baldwin  Motion's Avatar
quit driving it like a Camaro before you break something and have to get towed !!
