Old 06-29-2009, 12:40 AM
scuncio scuncio is offline
Default Safest Rust Remover - OK for seat belts?
I have a set of otherwise nice Deluxe seat belts but the adjuster in every buckle is rusted up. Can I soak the buckles in Safest Rust Remover without risking damage to the webbing material?
Thanks,
Tony
Old 06-29-2009, 04:52 AM
njsteve njsteve is offline
Default Re: Safest Rust Remover - OK for seat belts?
You're safe. Just keep an eye on it and don't soak it too long (like over several days) or it sometimes loosens certain paints that are near the rusted area - in other words it works too good sometimes and gets to all the rusted metal whether it's under paint or out in the open.
BTW, I used the purple stuff cleaner on the belt fabric and it cleans them great.
Old 06-29-2009, 07:15 AM
Thanks Steve, was hoping you'd reply. I took the belt covers off and have them partially freed up, but they could use a more thorough de-rusting. Will report back in a few days.
Tony
Old 07-02-2009, 04:01 AM
Worked amazingly well. Only problem is I don't know how to keep the slider bar from rusting back up. Any thoughts?
Old 07-02-2009, 04:37 AM
Some oil should do the trick. It's not like it's going to go through another 40 years of daily driver abuse and get the chance to rust again.
Old 07-02-2009, 04:51 AM
John Brown's Avatar
L3-12 Gunk/Radiator Specialties. Doesn't burn, doesn't stink. Has kept clean, bare steel parts rust free in my basement for at least the last 15 years. Takes a few days to dry, but doesn't leave a noticable film.
http://www.gunk.com/CAT_L312.asp
John Brown
