Old 07-26-2009, 08:43 PM
Fast67VelleN2O's Avatar
Default Looking for part number 4 Nova/Camaro crossmember
67-69 Camaro or 68-72 Nova. I have one, however, half of GM sticker is ripped off. Only showing last 3 digits of 006. Looking for complete number. Thanks in advance
Matt
Day 2 is Life.
Old 07-26-2009, 10:17 PM
John Brown's Avatar
Default Re: Looking for part number 4 Nova/Camaro crossmember
3899006
John Brown
Old 07-26-2009, 10:26 PM
John Brown's Avatar
Chevy parts catalogue is wierd. It lists it as fitting;
68-74 Chevy II, Nova (exc. 396)
67 Camaro w/4-Spd.
68-69 Camaro (396)
68-70 Chevy II, Nova w/ H/Per.., Sp. Hi Per. (396)
That would seem to contradict some of the info on crossmembers that is usually accepted as fact.
John Brown
Old 07-26-2009, 10:37 PM
This crossmember does not have the holes for a 4 speed shifter and it is not a Turbo 400 unit. I am guessing just a small block automatic crossmember
Day 2 is Life.
Old 07-26-2009, 11:05 PM
John Brown's Avatar
You're probably right. GM must have figured the installer would put whatever holes in it that were needed and superceded everything together.
John Brown
Old 07-26-2009, 11:18 PM
Thanks for the look up!
-Matt
Day 2 is Life.
Old 07-27-2009, 02:51 PM
goinforbroke goinforbroke is offline
How can I tell if my crossmember will work for big block/ 4 speed? I'm converting from sb/auto. Have the stock crossmember. Thank You
