Old 10-10-2009, 12:31 AM
dlv4540 dlv4540 is offline
Default 1969 L89 Block, heads and crankshaft
1969 4 bolt 396-375HP L89 block casting number 3955272 dated J-14-8 with front pad stamped T0527KG 19B400425. The block was cleaned and magged and is bored 30 over ready for the final hone to drop a set of pistons in it. I also have the standard steel 6223 crankshaft and a set of 3919842 service dated aluminum heads for the block. Nice set of heads complete minus the valve guides. $6500 for the set up and can ship if you cannot pick it up. I can be reached at 330-770-2517.
Dennis Vugrinovich
