Old 10-16-2009, 01:24 AM
68z28kk 68z28kk is offline
Default 396 engine code ID
I found an engine in an old machine shop with a stamped code of T0108AKT. I'm thinking the A prefix may be for marine use. The motor has some damage from a broken rod so if it isn't an automotive code it probably isn't worth saving. It was the bottom block with another motor stacked end to end on top of it so I could only manage to get the engine code numbers. It looks like it may have been a '70 L89 engine. Clint
Old 10-16-2009, 04:47 AM
427.060 427.060 is offline
Default Re: 396 engine code ID
According to the info I have it is either a 427 tall deck truck engine or 454 from an 1986 truck.
James
1974 AKT Truck 427 230 Mt L-43 60
1978 AKT Truck 427 220 Mt L-43 VIN E, 60
1986 AKT Truck 454 240 Mt LE-8 VIN W, 20, 30
1968 Beaumont SD396
Old 10-16-2009, 05:18 AM
When I first saw this motor about 10 years ago I only cleaned it up enough to read the KT. When I found the A prefix today I didn't think it would be good news. Thanks for the help. Clint
