Old 11-21-2009, 04:20 AM
sg1747 sg1747 is offline
Default negative battery clam
I just purchased a new negative battery clamp that goes on the alternator bracket. I have no idea how to attache it. Looks like a rivet maybe?? Any help would be appreciated.
Thanks,
John
Old 11-21-2009, 05:24 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: negative battery clam
I assume you mean negative battery cable? Most if not all are bolted to passenger side alternator bracket with a short bolt and star washer I believe. If alternator is on drivers side then to the front of the block.
Jake
Jake Dykstra
Dykstra Motorsports
Old 11-22-2009, 03:31 AM
Unreal Unreal is offline
I thought for 69 b/b, at a minimum, the negative cable attached to the block, not the alt bracket.
Old 11-22-2009, 04:27 AM
RamAirDave RamAirDave is offline
IIRC, I just squeezed it down in a press.
TheMuscleCarGuys.com
