Old 11-26-2009, 09:58 PM
mbxlesney mbxlesney is offline
Default Correct Coil bracket Info needed
Im in need of info on the correct coil bracket needed for a 1970 Nova w/396 and 17" Dual snorkel air cleaner (like on the 1970 Chevelle w/LS6). In my research I have found Chevrolet used several different angled brackets depending on air cleaner application from 25 Degree to 40 degree angles. But due to no part numbers on the bracket itself and my 62-75 Parts manual does not make any mention I was hoping the knowledgable members could give me a hand. Thanks in advance.
Kim
1970 Nova Fathom Blue L78 M21 3:55
1970 Nova Classic White 454HO THM400 4:10
Attachments - The Supercar Registry 431181-AngleDifferencecoilbrackets.jpg 431179-MY35degreeCowlinductionbracket.jpg
Old 11-29-2009, 03:19 AM
Default Re: Correct Coil bracket Info needed
I found the correct one I needed. Please disregard. Thanks
Kim
Old 11-29-2009, 03:30 AM
Can you post a pic of it for future reference?
I'd like to possibly correctly ID the few I have.
Thanks..
Old 12-01-2009, 03:21 AM
Rick ...What I ended up using is the 1969 Z28 and 1970 Chevelle with Cowl Induction. The base on these are 17" the same as the Dual Snorkel air cleaner. Problem is there are not enough owners of the latter to get any responses. I even tried Team Chevelle. Here is a couple pics you can use for reference. The Cowl Induction style has a Higher angle (35 to 40 degree) and seems to have the oval mounting hole open and there seems to be a notch taken out at the top.
Kim
Old 12-01-2009, 03:23 AM
Here is a different pic showing the angle compared to a regular coil bracket. Hope this helps you.
Kim
Old 12-01-2009, 05:05 AM
COPO 70 RS/Z28 COPO 70 RS/Z28 is offline
that bracket also runs on a 70 Z28
Carl
