Old 12-07-2009, 02:36 AM
x  Baldwin  Motion's Avatar
Default HEI with stock size dist. cap ?
I switched the motor from my 65 Chevelle to the 69 Nova. I had an HEI dist (mid 80's style)on the motor and there is no clearance for this in the Nova. Is there something smaller I can use or do I have to go back the points distributor?
Thanks in advance for your help.
Old 12-07-2009, 04:46 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Default Re: HEI with stock size dist. cap ?
If you have to go back to points distributor due to size constraints but don't want the points - you can install an electronic conversion kit from somewhere like Lectric Limited. All fits under stock cap, no other wires protruding, etc. Not the cheapest solution maybe but.....
http://www.lectriclimited.com/mainpage.htm
Jake Dykstra
Dykstra Motorsports
Old 12-07-2009, 08:28 AM
Plowman's Avatar
Plowman Plowman is offline
You will have to get new wires,or MSD small cap for HEI wires is the best.
Old 12-07-2009, 04:06 PM
Chateau Slate 66 Chateau Slate 66 is offline
I have the Pertronix II in my stock distributor and it has been great. Another option is Dave's small body hei conversion in your stock distributor. I have not used him, but others seem to like his stuff.
http://www.davessmallbodyheis.com/
Old 12-08-2009, 07:06 PM
Thanks for the input!
Old 12-10-2009, 12:21 PM
Unreal Unreal is offline
I got a Dave's unit, and I like it because the components are available at any auto parts store. He does have to machine the underside of the body to square it, so don't use a "special" core. I bought one for $5 and sent it to him for modification.
Old 12-10-2009, 06:20 PM
Chevy454 Chevy454 is offline
You can make a small body hei using either an MSD (if you want billet) or Chrysler (if you want widely available & in stock at parts stores) reluctor, and then a magnetic pickup (MSD is best bet)...it sounds a lot harder than it actually is. The only machining needed is to knock down the lobes on the shaft so the reluctor will fit over it...then, just hide your MSD box and your golden.
Old 12-10-2009, 07:02 PM
WILMASBOYL78's Avatar
I use the Crane Fireball in a regular Chevy points distributor and it works fine. Adjustable rev-limiter...never had a problem.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 12-10-2009, 07:26 PM
wilma
A few of the guys in the Pure Stock circles have had problems with the Crane pieces, specifically the rev limiter (cutting in too early, or sporadically throughout the rev range, etc)...
Old 12-10-2009, 07:42 PM
wilma
[/ QUOTE ]Adjustable rev limiter!!!!! What in your lawn tractor? You don't go over 3,500 rpm's anyway!
