Can anyone suggest a restoration shop for a bumper jack ? Also what is the correct plating process for the shaft? Silver or goldish? What is the correct color for the mechanism and the stand ,black or gray? 68 Camaro Thanks
I believe the shaft should be silver cad and the other parts should be gray including the jack handle.
Brian |
I believe the shaft should be silver cad and the other parts should be gray including the jack handle. Brian [/ QUOTE ] http://www.firewheelclassics.com/store/i...amp;SKU=TRKJACK That's also what they are showing here... DL
1968 Buick Conv Factory triple Black 1069 Buick GS Stage 1 1970 GS455 Stage 1 4-speed |
I did my jack handle in gray, but I think it is supposed to be black.
Is a Nova jack color the same as the camaro?
Is a Nova jack color the same as the camaro? [/ QUOTE ] Normally observed practice that I have seen is: Both silver and yellow cad. shafts. Gray base and mechanism. Black tire iron handle. I believe this is not 100% consistent as I seem to remember the possibility of black bases, but do not have the info handy. I am going to do my shaft in yellow shaft as I believe the silver ones possibly started life off as a very light yellow. Greg
Nova Research Project at chevynova.org |
the yellow or silver cad on the jack depends on what year the car is
68 Camaro
Is a Nova jack color the same as the camaro? [/ QUOTE ]The jack in old blue is silver cad with a gloss black handle, grey base and a grey load rest. |
