Old 02-11-2010, 03:55 AM
69L78Post 69L78Post is offline
Default 69 Z-28 Balancer question
What's the correct part# for a 69 302 harmonic balancer? A friend of mine is collecting parts for his Z and is wondering if he has the correct one or not.
Thanks,
Barry
Old 02-11-2010, 07:31 AM
Default Re: 69 Z-28 Balancer question
Part# 3947708 and is 8" in dia.
Old 02-11-2010, 07:41 AM
Post a picture and we will tell you. The timing marks are offset. Assembly line balancers are different looking than the NOS or over the counter part.
Old 02-11-2010, 01:53 PM
Thanks Mark and Sam. I'll see if I can get Al to send me a picture to post.
Old 02-11-2010, 06:45 PM
L78steve L78steve is offline
Offset from what?
Old 02-11-2010, 07:42 PM
John Brown's Avatar
The 69 timing mark is offset from the keyway groove. The 68 and earlier balancers have the timing mark directly in line with the keyway.
John Brown
Old 02-11-2010, 08:42 PM
Fast67VelleN2O's Avatar
Here is an original 1969 7708M assembly line installed balancer.
Day 2 is Life.
Old 02-11-2010, 09:32 PM
That is the one. As long as the timimg marks are offset. Looks like a real nice balancer.
Old 02-12-2010, 06:15 AM
The 69 timing mark is offset from the keyway groove. The 68 and earlier balancers have the timing mark directly in line with the keyway. [/quote
So I have this correct in my head, The 68 and earlier crank keyway is cut pointing towards #1 TDC and the 69 up crank keyway is straight up at #1 TDC.
Old 02-14-2010, 05:03 AM
JohnZ JohnZ is offline
The hub and keyway didn't change. The location of the timing index line on the inertia ring changed. The timing index line on the ring prior to '69 was directly in line with the keyway, and in '69 it was moved 10* counter-clockwise from the earlier location.
'69 Z/28
Fathom Green
CRG
