Old 02-21-2010, 09:34 PM
69 Post Sedan's Avatar
Default What is this bracket for?
This bracket was on my car. It was bolted to the carb/intake and it was for the throttle cable.
I had to change it when I went to a different air cleaner base. Is it for a Quadrajet carb?
Sorry about the blurry pictures.
Thanks in advance, Kurt
Old 02-21-2010, 10:19 PM
Default Re: What is this bracket for?
Kurt,
I`m assuming there are no part numbers on the bracket? I would assume that this bracket was installed my the same repair shop that the former owner was using, you know the one with the most invoice`s. See if you can find this repair work order for any leads?
Dan.
Old 02-21-2010, 10:34 PM
Correct, there aren't any part numbers on it. I will look to see if any paperwork has info.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
