![]() ![]() 1-4 are left to right on the top row. 5-8 are left to right on the bottom row. All intakes are raised pad 3933198 Intakes, not ground and stamped. All intakes have all markings intact. 1) Dated 1/14/68, No porting or corrosion, One outer runner mounting point welded. $500 2)Dated 8 or 9/16/68, no porting or corrosion, heater outlet nicely repaired(should not show with nipple installed. $600 3)Dated 2/7/68, Milled, Ported, Repairs at 2 front outer rummer mounting points, Looks nice. $350 4) No cracks or repairs. No porting or mods. Finish is dull. Needs to be reblasted or reskinned. $650 5) 1/5/68 Modified plenum(filled back in), some porting, no repairs, Negligible corrosion in rear coolant block offs. $600 6) 1/5/68, 2 runner repairs by me(need final blending and blasting, very nice intake overall. $500 7) 8/6/70, No cracks or repairs, 2 small plugs in rear cooling ports. $550 8) 1/4/68, cracks at both driver's outer runner mounts(repaired inside runners, heavy corrosion around thermostat and in cooling ports. Looks good, but needs welding. $400 |
