Old 07-30-2010, 03:20 AM
Default Between the Roofrail weatherstrip retainer & body
calls for a foam sealing strip which (I believe) is saturated with glycol. I have not been able to find this, what is everyone using? Seam Sealer? 69 Camaro.
James
Old 07-30-2010, 02:39 PM
Dusk Blue Z Dusk Blue Z is offline
Default Re: Between the Roofrail weatherstrip retainer & body
The dust that was left when I took my car apart looked like open cell foam with an adhesive backing, just like the home window weather strip sold at the Loews and HD. The sticky side was on the moldings so it was easy to clean off the residue. I can look to see if I still have the package that would give the width and thickness of what I used. When installed it should be just about completely collapsed by the screws. I think it might be used to stop wind noise as much as keep water out.
Mike
Old 07-30-2010, 03:53 PM
Fisher Body Manual calls for a "saturated polyurethane foam sealing strip"
Old 07-30-2010, 09:32 PM
Enoch Enoch is offline
Banned
3M strip caulk works in this application.
Rich.
Old 07-31-2010, 06:36 AM
Thanks...
Old 07-31-2010, 04:55 PM
Jonesy's Avatar
Jonesy Jonesy is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Enoch</div><div class="ubbcode-body">3M strip caulk works in this application.
Rich. </div></div>
Thats also what I used. My Van Nuys car had something similar to that originally.
