Silverado ABS pump running
my 2004 Silverado K1500 ABS pump was still running after the vehicle was shut off and key removed last night. After quickly reading through the 5000 page 20 lb owners manual I removed the square yellow 60 amp fuse from under the hood. The brakes appear to working ok, with the exception of the Ebrake. The ABS light and Ebrake light are now on all the time (unless I engage the Ebrake, then the light goes out).
I know there is some connection between the ABS and 4WD (they both don't work at the same time?)
I have been launching and retrieving frequently and my son has been making deliveries on the beach requiring the 4WD many times in the last few weeks.
I also had to slam on the brakes in gravel the other day to avoid getting rammed by a touron who wanted both sides of the road.
Found some info online, mostly stale on idiot forums.
asking here cause you guys are smart, patient and always right.
[img]<<GRAEMLIN_URL>>/wink.gif[/img]
