Old 10-21-2010, 07:59 PM
YENKO DEUCE REGISTRY's Avatar
Default Hood hinges
Is there a difference between the hood hinges from a '68-'72 Nova vs. a '67 Camaro?
Marlin
Old 10-21-2010, 08:19 PM
Default Re: Hood hinges
Chevrolet says Yes.
1968-75 Nova LH#3926829/RH#3926830.
1967-69 Camaro LH#3910667/RH#3910668.
Old 11-10-2010, 04:43 AM
L78steve L78steve is offline
Is there a difference between Nova SS hood springs and non SS?
Old 11-10-2010, 02:10 PM
Not to my knowledge, no change for the extra weight of the hood grilles.
Marlin
Old 11-11-2010, 02:51 AM
The reason I ask is I'm getting tired of the hood landing on my back. I'm thinking of trying a pair of Camaro SS springs.
Old 11-11-2010, 01:04 PM
Yea, I would change the springs as opposed to the hinges.
Marlin
Old 11-11-2010, 04:08 PM
SS427's Avatar
SS427 SS427 is offline
Make sure the hinge pivot points are not too well lubed up which people often do. They may also need to be re-pressed. I find this quite a lot of the time. Nothing wrong with the springs, just not enough friction in the hinge pivots.
Rick Nelson
Old 11-12-2010, 04:30 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">Make sure the hinge pivot points are not too well lubed up which people often do. They may also need to be re-pressed. I find this quite a lot of the time. Nothing wrong with the springs, just not enough friction in the hinge pivots. </div></div>
Most likely my problem. I use motor oil on the pivots.
Old 11-12-2010, 04:35 PM
Ouch! Use some white grease if they are too tight.
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 11-12-2010, 08:07 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body">Make sure the hinge pivot points are not too well lubed up which people often do. They may also need to be re-pressed. I find this quite a lot of the time. Nothing wrong with the springs, just not enough friction in the hinge pivots. </div></div>
Most likely my problem. I use motor oil on the pivots. </div></div>Why motor oil when there is many things for that application out there. That just attracts dust and unwanted dirt.
