Old 01-22-2011, 04:49 AM
Default LU block
I recently came across an LU block out of a 69 Camaro. I know LU is for a 427 (435 horse) aluminum head engine with HD clutch for a Corvette. Would this be an L-88 block? Colvin's book just says "L-71 Engine Alum Heads".
Thanks for any help.
Lynn
Old 01-22-2011, 06:27 AM
Enoch Enoch is offline
Banned
Default Re: LU block
Lynn, The L-88 used the same block as the other big blocks. It obviously had to be machined for 4 bolts as well as the oil cooler But a 512 is a 512. So yes this could be used as an L-88 block but as stamped it went into a L-89 aluminum head tripower Corvette.
Hope this helps, Rich
Old 01-22-2011, 06:55 AM
Lynn,
If you are asking if it was originally a L88 engine the answer is no. It was a L71 427/435HP tripower engine with aluminum heads. Still no slouch.
Jason
Old 01-22-2011, 02:37 PM
Alss's Avatar
Alss Alss is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">Lynn,
Jason </div></div>
[img]<<GRAEMLIN_URL>>/[/img]
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 01-22-2011, 02:41 PM
Thanks guys.
