"Day2" type BBC Build Up
Im having a 454 BBC Built up for my 1967 Firebird, The Car is "DAY2" style And I want to build the motor to RUN & SOUND the part-So far I have the parts I need for the look-But Im having some trouble as far as Picking a Camshaft-the motor has a Solid Crane powermax roller "nitrous" Grind- 246/254 -114 LSA - 615/636-I had A LOT of issue's with it-So I want to swap it out for a Hydraulic Roller from Howard Cam 242/242 110 LSA
620/620-Also I have 3 Different intakes I can run with this- 1st choice because it looks Cool is the Older Torker single plane that mounts carb at angle, Then 2nd is an equally old Holley "street contender" it is a low riser single plane with a "WINTER'S" Casting mark So it almost looks Factory-Then I have a Modern Edelbrock Performer permashine Dual plane-I also Need some Info On the Best Fit Headers to fit this car-Any Input as far as PROVEN BBC Combo's is appreciated- I had this motor in my Bracket car & Im having it Refreshed- its about 10:5.1 CR- 290 Large oval port heads with large valves heads all done up-BOWTIE Rods-Fully STUDED-Upper&Lowers-& I Want to have it RUN POWERFULL on the street AND strip-its going behind a Muncie 4 speed with 4:33 REAR Cogs..
1967 Firebird 496 BBC Stroker,M22 wide ratio,Thrush Mufflers Keystone Klassic's with Big&Little's,High Jacker Air shocks. |
Re: "Day2" type BBC Build Up
The vintage Torker is a Day 2 favorite as well as the Edelbrock C427.
Day 2 is Life. |
Tunnel ram two 600's
I was always told Tunnel Rams are a Nitemare to run Rite on the streets? Whats the trick to make them operate proper??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">Tunnel ram two 600's </div></div>
Try the 4224 660's instead...
Mark |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 396L35</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Plowman</div><div class="ubbcode-body">Tunnel ram two 600's </div></div>
Try the 4224 660's instead... </div></div> I would say try the 660's if you don't want good street manners or care about any fuel mileage at all. I just posted on the same issue over at Steve's Nova Site. |
Yeah I dont Care about Fuel mileage-I want it FAST& to look Old school-If I had the money ,I would do a Blower with 2 four's.. I am gonna drive it on the street And take it to the Track..My budget says use the parts I have on Hand, A tunnel look's So MEAN -But my budget is VERY tight this time around-Im looking for most bang for my buck...
Im having a 496 Stroker built-Its a copy of a older Linginfelter build-it's about 612 Ft lbs of torque on pump gas-So far -I have the Day2 Gold Moroso Valve covers-New in box-Vintage Holley Street Dominator intake-Fly Eye-Im gonna Mount some older Thrush Mufflers-I willpost some pic's As soon as It gets done at the machine shop-With this Motor with my M22 -it should be FUN!!
I would sy Tunnel Ram would give you 60 to 90 hp more and there is the "WOW" factor.
The trick for Tunnel Ram for the street is idle circuit too rich. Restrict the idle circuit in the metering blocks and run vacuum scondary carbs. I have run them for 20 years.
