Old 08-01-2011, 09:07 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
Default 1969 L78 bypass hose
Looking for a correct bypass hose for my L78 water pump to intake. All I can find are hoses with an 85-90 degree bend. Bend on original looks like its approx. 15 degrees.
Martin
Old 08-01-2011, 10:08 PM
302moz 302moz is offline
Default Re: 1969 L78 bypass hose
Use a straight piece of the correct ribbed hose. It will bend without any kinks. John p.s. just put a waterpump on a bb and the straight hose worked out fine.They do not make a 15 degree bend hose.
Old 08-01-2011, 10:28 PM
TDW TDW is offline
When I need a hose with a particular bend, I go to the local parts store and look through the hoses hanging on the wall. I always find something that has the bend that I need. The hose that has the bend may have a couple of different bends and be a mile too long. If that's the case, I cut the bend that I need out of the "donor" hose.
PS...Bend a coat-hanger to fit the bend you need and take it with you.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 08-01-2011, 10:50 PM
Good idea Tony!
Old 08-01-2011, 10:57 PM
Yenko Paid Member
Thanks for your suggestions guys...I'll get at it tomorrow.
Martin
