1968-1972 Chevelle 4.10 12 bolt posi Rear. Nothing special code. $950.
1968-1972 Chevelle 3.31 12 Bolt Posi Rear. Has ring gear spacer. Nothing special code. $825. 1968-1972 Chevelle Moser 9" Rear End. Aftermarket housing, 3.90 gears, 31 spline axles, traction Lock posi unit. $1300. 1970 Camaro 12 Bolt 3.73 Posi. Coded COZ out of Z28. Richmond gears, posi unit has some marks, nothing major $900. 1969 427 block. 512 casting .030" Dated May of 1969. was decked, no codes or vin. $1800. 1968 427 Block. 321 casting. Out of Corvette L89, Fresh .060", was discussed here on SYC. Car is known. $2200. 1967 327 shortblock. 657 casting, no codes or vin, .030", 11:1 L79 pistons, steel crank. Needs freshening. $600. Service dated 291 square ports. Have been ported but nothing major. Valves are present but no other hardware. $600. 1970 Chevrolet 454 291 square port heads. No porting. Dated K-28-9 and L-8-9. Nice used heads. No guide plates. $900. 1969 Chevrolet 396 or 427 square port heads. No porting. 3919840 dated C-35-9 and C-27-9. Complete. Good cores. $900. 1971 Camaro Z28 350 block. 3970010 dated C-24-1. Stamped V0326CGP. Vin 11N563805. Standard bore 4 bolt. $675. Lots more but this is stuff off the top of my head. Spaces G41 and G42. -Matt
Day 2 is Life. |
matt, i will be there on friday. i will stop by.
buddy
69 camaro Z-28 burnished brown X-77 bought 1978 70 camaro Z28 forest green M40 black vinyl roof PROJECT 99 camaro SS Hugger Orange 6speed no t-tops 1 of 54 11 cts-v black diamond edition wagon 556hp GONE 15 camaro Z/28 white AC brand new |
More stuff:
1971 Muncie M22. Very nice low mileage unit. No issues whatsoever. Original GM gaskets with the tabs as well. Out of Pontiac. $1500. 1974 GTO Hood and Shaker assembly. Original GM stuff. $750. NOS 64-66 Mustang quarters, outer wheel houses, and trunk drop offs. All NOS FoMoCo. $1000 for everything. Small block and big block trap door Corvette oil pans. Small issues but will straighten out easily. $200 each. 461 X heads dated late 1961. Bare. Never been modified ever. $675 pair. 78-81 Corvette glass t-tops. PPG replacements. Very nice. $600 pair. 1962 Chevrolet 409-380hp intake manifold. 678 casting number. No issues. $350. 69-75 Corvette tilt-tele column in silver with steering wheel. $550. 69-72 Chevelle floor shift column. Non tilt. $75. Lots more. See you there.
Day 2 is Life. |
I'll be set up with fast
1970 Chevelle/El Camino CCF coded(3:31) D 22 70 dated 12 bolt rear complete drum to drum /drums dated D 25 70 has moroso brute strength posi unit in it . $1400 obo 1970 Nova CBS coded (3:31) 12 bolt housing dated L 29 69.Spring perch's have been cut off .But i have a new repo set to go with it ..$450 obo 1970-72 NOS door skin $350 Plus a lot .. ![]() ![]() ![]() ![]()
I am out there finding it so you don't have to . |
Looks like its going to be rear-a-palooza.
Day 2 is Life. |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fast67VelleN2O</div><div class="ubbcode-body">Looks like its going to be rear-a-palooza. </div></div> The late Art Houser would be proud .
Art knew his hind ends! When is Carlisle?
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro. |
Jed, Carlisle starts tomorrow Wed the 28th thru Oct. 2nd
Son of A! Thanks Jeff.
Picture of our fast67 spot from yesterday before the storm .Hope its better today.
