Old 11-22-2011, 06:35 PM
69L78's Avatar
69L78 69L78 is offline
Default Help Identifying this part?
Can anyone identify this and what it would have been on. As you can see from the pic, it is not a stamped steel plug wire stand.
Old 11-23-2011, 11:18 AM
Default Re: Help Identifying this part?
Do those parts belong together? Or is that Frankentein?
Old 11-23-2011, 01:08 PM
69L78's Avatar
Here are a couple more pics, this is not a made up part.
Old 11-23-2011, 03:32 PM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body">Do those parts belong together? Or is that Frankentein? </div></div>
Yeah, that rod doesn't seem to belong attached to that bracket.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 11-23-2011, 03:46 PM
enio45 enio45 is offline
Could be the muffler bearing shift lockout rod for the BB?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-23-2011, 03:58 PM
Are you asking for info, or quizzing?
Almost looks more red than orange, so could be off a vintage Buick, or even an old International, as they both used similar paint at different times. No telling how old. I believe you believe it is not a made up part, but there is no telling what someone may have done with it over the years. Appears to be a stamped steel plug wire tower with an integrated arm for a carb return spring. Apparently bolted to an intake or exhaust manifold, most likely the intake. That part is easy.
I have no idea why it would have the extra hole for the (apparent) linkage rod, or what that rod would have gone to.
You could disassembe it and use a jeweler's lupe to inspect the hole that the rod goes through. If the hole was drilled, then someone made the part this way after production. If it was stamped, then... I really don't know.
Just my .02.
Old 11-23-2011, 05:27 PM
Looking at the part - i can not think why the rod would be on there....with a solid mounting on one end (where the rod is currently attached) , what would the other side be used for related to the top of the engine??
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 11-25-2011, 03:02 PM
69L78's Avatar
Here are a couple pics without the rod.
Old 11-26-2011, 05:58 AM
Do the lower holes (the wider ones) line up with bigblock or smallblock intake manifold bolts?
Or neither ?
Unless the rod attached to some type of bellcrank or lever I am at a loss and even then I would question it... maybe BIG TRUCK? C30 366?
Survivors, restored cars, &amp; other photos
Old 11-26-2011, 05:08 PM
69L78's Avatar
Thanks James, you finally eliminated it being from a BB Chevy, it is wider.
