Old 01-09-2012, 02:55 AM
302moz 302moz is offline
Default 68 camaro consule restoration
Is there anyone that restores 68,69 consules?I have a burn in the top piece that needs to be repaired. Not sure how to repair it. thanks John
Old 01-10-2012, 07:19 AM
70post 70post is offline
Default Re: 68 camaro consule restoration
is the burned area in a hard plastic textured surface? Can you post a pic?
Patton Glade
70Post Restorations
Austin, TX
Old 01-10-2012, 05:14 PM
yes it is in the grain area. thanks John
Old 01-12-2012, 06:03 AM
If you can find a donor piece of the same console plastic then the bad area can be cut out, donor piece put in and then with enough time and patience the "seam" can be hidden. I've done this on a couple consoles and console related pieces.
It'll have to be painted after that type of repair.
I guess you could also try to find a local auto vinyl/leather repair specialist and see if they have any ideas.
Patton Glade
70Post Restorations
Austin, TX
