Old 01-20-2012, 03:15 PM
Zach Carter Zach Carter is offline
Default 2012 24ft Maxey Drop-n-Load Air Ride Car Hauler
<span style="font-weight: bold">New 2012 Maxey Air Ride Car Hauler</span>
The is one of the most innovative car haulers on the market. It rides on an air ride suspension which allows the deck of the trailer to drop flush to the ground to load the lowest vehicle. With the push of a button you can lower and raise the deck of the trailer to any height and tailor the air pressure in the bags to your load. $5900 buys it.
Ebay Link: http://cgi.ebay.com/ebaymotors/?cmd=...ELX%3AIT#v4-42
You Tube Link: https://www.youtube.com/watch?v=mbr5e-RGJBk
7000LB GVWR
1/8&quot; DIAMOND PLATE STEEL FLOOR
83&quot; DECK WIDTH
4-NEW MORTON SILVER MOD 15&quot; WHEELS
2-35K DEXTER SPRING BRAKE AXLES
4-NEW 205-75R-15 TIRES
4 – HEAVY DUTY AIRBAGS + 4 SHOCKS
7-WAY PLUG
ELECTRIC BREAKAWAY KIT W/CHARGER
SEALED WIRE HARNESS
5&quot;CHANNEL FRAME
FLUSHMOUNT D.O.T. STOP, TAIL, &amp; TURN LIGHTS
5&quot;CHANNEL WRAP TONGUE @ 51&quot;
LICENSE PLATE BRACKET
SAFETY CHAINS
2&quot; X 3/8&quot; RUBRAIL &amp; 10-STAKE POCKETS 4&quot; X 3&quot; X 3/16&quot;
5000LB RAM SWIVEL JACK OR 7K DROPLEG JACK
MECHANICALLY CLEANED AND PREPPED
4 - 9&quot;X32&quot; DIAMOND PLATE SINGLE AXLE FENDERS
1 COAT PRIMER
3&quot; CHANNEL CROSSMEMEBERS 16&quot; ON CENTER
2 COATS ACRYLIC ENAMEL PAINT
2 5/16&quot; ADJUSTABLE FULTON RAM COUPLER
4-BULL NOSE D-RINGS
2 3/8&quot; PIPETOP FRONT TOP RAIL
PAINTED UNDERNEATH
Options
8 360 DEGREE ROTATING D-RINGS
SOLAR CHARGER
WIRELESS REMOTE CONTROL
FLUSHMOUNT LED LIGHTS
ST 225-75R-15 TIRES
SPARE TIRE/WHEEL MOUNTED
ROCKSHIELD SMOOTH FORMED STEEL W/WINCH MOUNT
ALUMINUM PADS ON FENDERS
Zach Carter
1969 Biscayne L72 M22 Real
1972 Nova SS-Former Drag Car
