Old 01-25-2012, 06:39 PM
69Tom 69Tom is offline
Default 1969 Nova Build Sheet--yours?
Finally! After all these years and cars, I get a build sheet hidden under the back seat bottom. It's only a 6-banger, but hey, I'll take what I can get. So I gently pull it out from between the springs only to look and see...it isn't for my car.
Awesome.
In any event, if it's yours, contact me.
1969 Nova
SEQ: 062
MO.: 01
DAY: 16
STYLE: 11427
PLT. OPT 16: WRN
BODY NUMBER: 258790
TRIM COMB: 731
EXTER. PAINT: LWR 65; TOP UPR. 50
Additional Codes:
B80
B84
B90
D99
ZJ5
Old 01-27-2012, 02:58 PM
WILMASBOYL78's Avatar
Default Re: 1969 Nova Build Sheet--yours?
Very common to have the wrong buildsheet in the seat...our 69 6 cyl. car had two...the right one and another from a different car. Keep looking maybe you'll find yours...I have found them in the front seat also.
wilma
ps..look under the dash...sometimes you will find the larger broadcast sheet...
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 01-27-2012, 03:18 PM
The 69 L78 I have for sale had it's build sheet and another in the rear seat also.
Old 01-27-2012, 04:54 PM
----Red Alert had the wrong build sheet in the drivers side bucket seat. It was for a regular Chevelle convert with black bucket interior......Bill S
Old 01-27-2012, 09:51 PM
Jefferson's Avatar
Jefferson Jefferson is offline
Both build sheets to my 72 Rally. Under the rear seat cushion and between the gas tank and trunk floor.
Old 01-27-2012, 11:12 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jefferson</div><div class="ubbcode-body">Both build sheets to my 72 Rally. Under the rear seat cushion and between the <span style="font-weight: bold"><span style="text-decoration: underline">gas tank and trunk floor</span></span>.</div></div>
The only Novas that have it on the gas tank are Van Nuys cars like the 72 one above. That was because full frame cars were also built there.
Willow Run did not place them on the gas tank. I posted a long write up on Nova Build sheets in an older thread which was recently revived here Nova Broadcast sheets
Greg
