Old 02-03-2012, 01:14 AM
the427king's Avatar
Default 69 JL8 rear
wanted real jl8 1969 rear. gear ratio not important. Looking for a complete rear if possible. Not looking for a make up welded rear. PMs only please
No Fisher priced toys here
Old 02-03-2012, 02:35 AM
Fast67VelleN2O's Avatar
Default Re: 69 JL8 rear
http://philadelphia.craigslist.org/pts/2722255378.html
Day 2 is Life.
Old 03-02-2012, 02:20 AM
69Znut's Avatar
69Znut 69Znut is offline
The JL8's are all Stamped QX and are 3.73 ratio the same ratio used on the drum axles for the 302 Z/28.
Also the JL8's have more clutch plates than a standard Z/28 differential and the carrier numbers are different.
Read Untold Secrets by Wayne D. Guinn before you make a purchase.
I have a JL8 but its a Green Sheet, Heavy Duty Service Axle not the production street version. The HD Service Axle uses B-car axles and bearings and is a half an inch narrower than a standard drum flange to flange.
A factory JL8 is wider than a standard drum axle, flange to flange. JL8's are running 14k and Service Axles are heavily hunted down bc as and over the counter item it was added on to any car like the headers and cross rams and was the first race version built and offered over the counter prior to the build of the factory offered JL8 street version.
JL8's were not limited to the Camaro's and could be ordered on Nova's and Chevelle's but I think the ratio was still 3.73.
Hope this helps you when the time comes.
Old 03-02-2012, 02:55 AM
the427king's Avatar
Thanks, excellent information.
Old 03-02-2012, 03:01 AM
Guest
Posts: n/a
King....what exactly is a make up welded rear? Never heard that term used before.
Old 03-02-2012, 03:47 AM
jl8z28 jl8z28 is offline
JL8 could be ordered in a lot of different ratios. My 69Z28 is a factory JL8 car and has QW=3.55 rear
Old 03-02-2012, 04:04 AM
69Znut's Avatar
Make up welded rear = Clone Axle
I also wanted to correct the following after brushing through my old books.
The HD Service and Green Sheet HD axles came with the 22 plate clutch packs not the street version which was 18 plates.
Also my other correction,, the JL8 can come in any of the Posi Q? ratio selections offered for 1969.
The 67 and 68 did not have the RPO JL8 but the HD Service Axle was offered over the counter back then and many builders were making there own Green Sheet axles or buying the HD kits.
Sorry, its been a while since I've been in these books.
Old 03-02-2012, 02:48 PM
Plowman's Avatar
Plowman Plowman is offline
Some nickle rod and you will be fine. HA! HA! *Paul*
