Old 04-15-2012, 05:19 AM
Tommy Tommy is offline
Default Whats this wire go to?
I have forgotten what this was for on the 68 Nova.
Tommy [img]<<GRAEMLIN_URL>>/[/img]
Old 04-15-2012, 05:22 AM
ssl78 ssl78 is offline
Default Re: Whats this wire go to?
My guess would be back up lite switch
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 04-15-2012, 05:26 AM
does it push through the firewall? This wire/plug was pushed out of the way before I owned the car and it hasn't had back up lights for a few decades either.. I do have a couple holes in the firewall that this plug would fit.
Old 04-15-2012, 03:53 PM
yes it would push into the firewall and the other end coming from the trans would be a molded rubber male end. This is a manual trans car correct
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 04-15-2012, 04:03 PM
Plowman's Avatar
Plowman Plowman is offline
On the drivers side between master cyl and trans tunnel.
Old 04-15-2012, 04:16 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ssl78</div><div class="ubbcode-body">yes it would push into the firewall and the other end coming from the trans would be a molded rubber male end. This is a manual trans car correct </div></div>
Yes, its a 4 speed. I found the correct spot for it after looking some more. I doubt the backup lights have worked on my Nova since the early 70's. Its had lots of trans/shifter combos. When I got it you could nearly pull the trans up through the floor because the tunnel had been hacked on so much. Well, at least I know what this if for now and I can do something with it later. Thanks guys [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
