Old 04-23-2012, 03:49 AM
Carleen's Avatar
Carleen Carleen is offline
Default Motion on ebay
http://cgi.ebay.com/ebaymotors/1969-Bald...=item2ebd97015f
Old 04-23-2012, 03:58 AM
Carleen's Avatar
Default Re: Motion on ebay
Looks like a clone to me
Old 04-23-2012, 04:04 AM
Carleen's Avatar
Is this the same car that we discussed earlier?
Old 04-23-2012, 04:07 AM
Carleen's Avatar
This Baldwin Camaro is finished in its original garnet red exterior with its original black deluxe interior. This car is documented with its original protecto plate from Baldwin Chevrolet. It has its original 427| L-88 engine, 512 block, actually dated correct for the car. It is powered by an original Holley NASCAR 950 CFM 3 BBL carb which sits on top of its original 427 X Edelbrock aluminum intake. The aluminum heads (074) are full race prepped and the engine produces well in excess of 550hp. The engine is standard bore. Power is delivered thru its M-22 rockcrusher transmission and ends up on the ground thru its factory, original BE coded rear end (4.11 on its pop) which now holds 4:56 gears. Exhaust exits thru its original side pipe set up which is all polished stainless steel, starting at the headers and all the way back. This car has power steering, power front disc brakes, tilt wheel, full gauge pkg with console and a center mounted clock. This car is also a factory radio delete car. The transmission has a Hurst reverse lock out set up, a 140 mph speedometer, and an 8000 RPM tach. In the trunk are still mounted its twin Dupree electric fuel pumps and on the lower rear fenders you can see the outlets for the individually adjustable air shocks. The dash has a Holley pull choke for its carb. Besides its Lakewood traction bars, it also has Cure ride shocks in the front. The car has many, many original Motion parts that are too many to list. The paint scheme is typical motion for the period. This is a real Baldwin Camaro and was "motionized" sometime in its early history, either by its original owner or one after that. This car is as original as any (documented by Joel Rosen himself) Camaro you will find. If you are looking for a real Baldwin Camaro and like Motion and Joel Rosen's efforts to produce the finest street or track cars of the era, this is what you want. There are very few original Camaros out there that can say they are original Baldwin Camaros. Her is your chance for one. Please feel free to ask questions. Please don't call unless you are a serious buyer. This is a serious car for a serious buyer. All serious cash offers will be considered and trades with cash will be considered.
Additional pictures are available upon request. An inspection can be arranged by appointment only. If the car needs to be shipped, we will ensure the car is available for the transporter's schedule. Reasonable offers will be considered. If you have questions or want to discuss the car, contact Randy at 612-619-2252.
Old 04-23-2012, 04:12 AM
Carleen's Avatar
Here it is https://www.yenko.net/ubbthreads/ubbt...094&page=1
Old 04-23-2012, 05:08 AM
Carleen's Avatar
Old 04-23-2012, 05:11 AM
Carleen's Avatar
Old 04-23-2012, 01:45 PM
Atuckman Atuckman is offline
wonder what the documentation by Joel is...
Old 04-23-2012, 02:19 PM
COPO COPO is offline
This car was discussed before and clearly the trim tag is a repo.
Old 04-23-2012, 04:10 PM
Subject VIN 124379N605956
Less the BS and bling, it'd be cool!
