Old 05-27-2012, 02:06 PM
Ngtflyr Ngtflyr is offline
Default CE replacement block or date code correct block
We have a customer with a 67 BB Pace 4spd pace car undergoing restoration. He knows the owner history and (I believe) the second owner had the block replaced at the dealership. The replacement motor is also long gone, the car was raced extensively. We already have a CE block that is in the right timeframe for the car. Now the owner has been cruising the internet and has seen the following link in which Jerry MacNeish says there is no intrinsic value to a CE block without paperwork for that specific block.
CRG CE discussion
Here is the owners question:
As we discussed this afternoon-- Here is the link I mentioned, on the CRG website, where Jerry McNeish was weighing in with his opinion on CE blocks vs. other alternatives (see reply #6). This discussion dates back to 2009, maybe that matters somehow? anyway please check this out and let me know what you think...
IMHO a CE block without paperwork is better than a date code correct blank/decked block. I also believe it is better than a restamped date code correct block.
I am wondering what your opinion on this matter is. Thanks
Dave
Old 05-27-2012, 03:34 PM
XXXGoldL34M20's Avatar
Default Re: CE replacement block or date code correct block
<span style="color: #3333FF">&quot;I'll put my &quot;Legends&quot; concours judging hat on and give my best professional opinoin. If you want to have the most technically correct car if the OEM engine is gone, then a dated correct original engine is the best way to increase the value of the car and authenticity of the car. Next would be to install a restoration block, this is one that the casting date lines up with the car with restamped engine assembly numbers and vin numbers.
CE blocks do not have any value from a restoration stand point unless you have the dealer installed paperwork that came with the car. Having a CE block in a restored Z28 or SS, COPO, etc will net you very little points. Only thing worse than a CE block would be an over the counter Target motor from GM.
Hope this helps,
Jerry&quot;
</span>
I am going to agree with Jerry on this one,I rather have a correct dated block than a CE block. Today it just seems like it is the &quot;IN&quot; thing to do right now by putting in these CE blocks and saying that the original motor was blown and replaced by a CE block, but it does not mean squat without the proove. I personally would not pay extra money for a car with a CE block and i do not think it is any better than a date code correct block. A lot of restorers buy Starters/Alternators/Carbs/Smog/Distributor Etc... with date code correct components, why not do the same with a Block. Just my opinion.
m22mike's Avatar
m22mike m22mike is offline
Dave
Aside from &quot;Points Judging&quot; I agree with your take on using the CE block, it's real and could have been. At this point in time I do not put any value on a restoration block. I think most are tired of seeing and hearing off them.
I have a closely dated JH block in my Black Camaro, that is another option, but as far a adding value, who know's.
Don't over think it, just use the CE. JMO
Mike
Old 05-27-2012, 06:32 PM
Stefano Stefano is offline
Some well known judging venues have lead people to alter VINs and trim tags on respective components in order to comply to judging standards.
I have never thought that this was the &quot;best&quot; way to handle such a situation, regardless of the value effect it has on a particular vehicle.
There are many well known cars which have scored well at National events which have had these components stamped or altered.
My opinion is that properly restored vehicles, even with out their original drive trains, should still have a chance to score well and NOT be out of contention for a &quot;High&quot; level award, just because of this scenario.
This is my opinion, best to worst for these situations.
1)Born with numbers matching drive trains. This is the best thing to have, that which originally came from the manufacturer, in that particular vehicle.
Some do not understand the term, but it seems very clear and concise to me.
2) CE Replacement, with dealer paperwork. If there is proof that a CE replacement engine was installed by a dealership because it needed to be replaced then that is the next best thing to having the original born with engine, when it is NOT available.
3) If a documented CE is not available then and original engine from another like kind vehicle built during the same time line, would be the next best thing. VIN and date coded correct, original, but from a different, yet similar vehicle.
4) Date coded correct with the correct suffix code also, but NO VIN. Some blocks were not stamped with VINs for various reasons and some were stamped and built as complete warranty replacement assemblies.
5) A CE or factory replacement engine with correct dates.
6) A correct date coded and casting number block with a blank deck/pad.
7) A correct date code and casting number block with an incorrect suffix or pad stamp, but built to correct standards of the car.
8) A properly date coded and re stamped &quot;restoration&quot; block.
9) A correct casting number and size, but NOT date coded correct.
10) A correct style engine but not numbers matching or date coded correct.
11) Just any engine, Like an LS engine in a first gen Z28. That should be a maximum deduction in points for concours correct judging.
Click to visit the Nickey Performance Facebook--&gt;
Old 05-27-2012, 07:11 PM
I have a correct date coded block in my 1969 Z/28. At least the engine block came from the same time frame as my car did so they are the same age. A CE block could be dated 70-71 for a 1969 car. I would rather have the same date codes as the car itself. JMO though!
luzl78 luzl78 is online now
Dave, is the pace car the one owned by Tyler?
Old 05-27-2012, 07:21 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">I have a correct date coded block in my 1969 Z/28. At least the engine block came from the same time frame as my car did so they are the same age. A CE block could be dated 70-71 for a 1969 car. I would rather have the same date codes as the car itself. JMO though! </div></div>
So if your Z28 had a dealer invoice and owner history stating/ showing that a CE replacement block dated 1970 was installed in 1970 under GMs warranty at a Chevy dealership, you would have pulled that engine for a date code correct one?
Old 05-27-2012, 09:41 PM
I would agree with Stephano's list completely with one exception. I'd move #8 to #12. I don't agree with restampng anything in the name of restoration. I don't care what reasons or excuses the current owner makes, somewhere down the road it will become the &quot;original&quot;. The reason why real ones are worth more money is because they ARE real.
Just my opinion.
Verne [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-28-2012, 12:21 AM
Jeff,
No, it is owned by someone who has had the car since high school in the late 70's. It's been off the road since the mid 80's.
Dave
Old 05-28-2012, 01:51 AM
69LM1's Avatar
69LM1 69LM1 is offline
Personally, I think that A &quot;CE&quot; block would be my preference to a date correct block if built correctly.
But I did'nt sleep in a holday inn last night [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Original numbers matching cars are really at the top. In many cases, the engine is what made the car special, IMO.
RichPern
Rich
Rich Pern
69 Camaro COPO "Tin Soldier"
