Old 06-03-2012, 06:02 PM
foster foster is offline
Default block numbers heads
anyone know these codes the block front pad CEA 1339 15 AND THEN A CODE, VO 204XCD THE HEADS ARE 399149 THANK YOU
1967 SS CHEVELLE SURVIVOR
1968 SS MATADOR 396 CAMARO
1967 CAMARO SURVIVOR
Old 06-03-2012, 10:46 PM
x77-69z28's Avatar
Default Re: block numbers heads
there has to be a number in between the E and A. that would indicate the year of the engine. the A is the second run of engines, then a sequential number. i havent seen a CE motor with a regular assembly code before, but V is flint assembly plant 0204 is feb 4, im stumped on the XCD. what kind of car is it in?
Old 06-03-2012, 10:53 PM
x77-69z28's Avatar
quick internet search, general concensus is that it is a crate engine as opposed to a CE short block. thats all i could find out
buddy
Old 06-04-2012, 12:52 PM
hi yes iam that stumped also i thought that might be a corvette LT1 code FOR A 70-71 CORVETTE and the heads never herd of that 399149 head#s thank you buddy
Old 06-04-2012, 02:37 PM
69biscayne 69biscayne is offline
found this on a corvette site.
3991492 was a service only casting that was machined as a replacement for all earlier big port/big valve heads, so check the casting numbers again. They could very well have been used for "LT-1 crate engines".
The "2" may just not show up or be very faint.
