Old 06-04-2012, 01:58 AM
daverd daverd is offline
Default Accel distributer parts....needed
I have an accel dual point distributer(tach drive)
It's missing the upper shaft bearing ,plate
And hard ware (this is the plate and bearing
That's above the points....)
HELP!!!! 30103T is the model number.
Thanks Dave
2017 impala (wife’s car)
Old 06-04-2012, 12:25 PM
John Brown's Avatar
Default Re: Accel distributer parts....needed
It might help if you list the series of Accel distributor that you need the parts for, such as 340xx, 370xx, 220xx.
John Brown
Old 06-04-2012, 11:38 PM
whitetop whitetop is offline
Dave, all the good 30100/30200/30202 etc and 37100's shared the same internal guts-does not matter if you buy one for a Chevy, Ford or Mopar. Only the shaft length is different. I see complete used ones for cheap on ebay...$20-25 or less.
There are differences between the 30100 and 37100 series so you need to buy what ever series you have but does not matter if it's a Ford, Chevy or Mopar. I think you are looking for the stabilizer plate assembly??
All the bearing and thrust washers are available at any good bearing co.I just bought a bunch of bearings and thrust washers for my Ford 30201. The originals were INA bearings and the part # is right on the bearings and the INA bearings/thrust washers, torrington bearings are still available from INA
Here is my Accel I had chrome plated. the used distributor in the center has the stabilizer plate I believe you are looking for?? The two boxes on the right are the rebuild kits for these distributors. Has all the springs, clips etc.
Old 06-05-2012, 04:26 PM
Thanks whitetop
It's a 30103T
For a 455 olds
Dave
Old 06-05-2012, 07:04 PM
micky69396 micky69396 is offline
I may have one from a Pontiac, I'll look tonight.
Micky Hale
Hale Performance Consultants
Engine Parts Sales & Service
Old 06-05-2012, 11:08 PM
Thanks mickey lemmie know.
Old 06-06-2012, 12:31 AM
67 Nova Boy's Avatar
Dave...will this help you any? Not my auction.
http://www.ebay.com/itm/VINTAGE-ACCELL-D...=item35b992c3de
Dave
67 Nova Boy
