Old 09-01-2012, 08:00 PM
sah62's Avatar
sah62 sah62 is offline
Default GM 3905525 Metering Valve Disassembly and Rebuild
I've just completed disassembly and rebuild articles for the GM 3905525 metering valve made by Bendix for 1967 - 1969 GM vehicles. I've also got a new seal kit available that I'll post in the classifieds. Here's the disassembly article:
https://www.musclecarresearch.com/gm-3905525-autopsy
The rebuild article:
https://www.musclecarresearch.com/gm-3905525-rebuild
I don't yet have a reproduction of the Bendix rubber dust cap. I'm exploring my options to see if it can be done economically.
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
1995 Chevrolet Impala SS
2019 Lincoln MKZ 3.0T AWD
Old 09-02-2012, 12:10 PM
m22mike's Avatar
m22mike m22mike is offline
Default Re: GM 3905525 Metering Valve Disassembly and Rebuild
Outstanding work Scott, I see an order in my future... [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-02-2012, 01:49 PM
Wow Scott, nicely done! Love your detailed descriptions/instructions and the clear photos. VERY helpful! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 09-02-2012, 05:51 PM
Donnie's Avatar
Donnie Donnie is offline
I placed my order!
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 09-02-2012, 07:32 PM
L72Chevelle L72Chevelle is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Donnie</div><div class="ubbcode-body">I placed my order! </div></div> X2 Thanks Scott!
Old 09-04-2012, 08:39 PM
68SSCamaro 68SSCamaro is offline
Thanks, perfect timing. I'm just installing a rebuilt power brake booster and master cylinder and the brake lines on my car. Ordered 1 set.
Martin
Martin Foltz
68 Camaro SS-396
L35/M20, Corvette Bronze, black vinyl top
George Olsen Chevrolet San Francisco
Old 09-06-2012, 02:03 PM
dl7265 dl7265 is offline
Scott,
What a great tutorial. What about the '70 style that does not have the large nut on the end ?
I know Steve Gregori told me he rebuilds them and has the unit phosphate plated while apart.
Thanks,
DL
1969 Buick GS Stage 1
1970 GS455 Stage 1 4-speed
Old 09-07-2012, 01:06 AM
sah62's Avatar
I wish I knew how Steve is rebuilding those 1970 1233464 valves because I can't see any way to get them open! If there's a way to open it that doesn't require cutting I can probably come up with the parts.
Scott Hollenbeck
Old 09-07-2012, 11:08 AM
njsteve njsteve is offline
Great info! Do you offer the parts/o-rings for the other versions of the combination valve? This is the one from my 72 Firebird. There is also a similar cast iron bodied one that does not have the &quot;L&quot; shape.
Old 09-07-2012, 12:27 PM
sah62's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">Great info! Do you offer the parts/o-rings for the other versions of the combination valve? This is the one from my 72 Firebird. There is also a similar cast iron bodied one that does not have the &quot;L&quot; shape.</div></div>
I do. I currently have two kits (proportioning and pressure differential) available for the Kelsey-Hayes valve you have pictured. Here's the disassembly article:
https://www.musclecarresearch.com/19...-valve-autopsy
I'm still working on the kit for the metering valve and that's what's holding up a rebuild article. If you can't wait assembly is just the reverse of disassembly. These are the seal kits:
https://www.musclecarresearch.com/kh-iron-combo-kit-1
https://www.musclecarresearch.com/kh-iron-combo-kit-3
I hope to have a kit for the metering valve &quot;soon&quot;.
Scott Hollenbeck
