Old 10-07-2012, 12:54 AM
67 Nova Boy's Avatar
Default Cross ram throttle set-up
Any one have a picture of the throttle set up on a Cross Ram? Need picks of the peddle set-up inside car and where and how it goes through the firewall.
Dave
67 Nova Boy
Old 10-08-2012, 02:26 AM
Nova Jed Nova Jed is offline
Default Re: Cross ram throttle set-up
From what I know....the CrossRam throttle setup was like a 6cyl Nova or Camaro except the cable through the firewall was longer and hooked up to a bracket in the middle of the intake. One of the old Ricks First Gen catalogues had the whole entire setup listed for a 69 CrossRam Z. It wasn't hard linkage. The pedal should just be like a standard 6 cyl Camaro Nova type where the cable comes through the pedal and has a plastic bushing that then snaps into the hole on the pedal bracket. As far as all the linkage is concerned with the carbs on the intake...not sure.
Jed 69,70,71 Nova's 1955 Bel Air and a 69 Camaro.
Old 10-08-2012, 11:12 AM
Plowman's Avatar
Plowman Plowman is offline
Good info on the Cross-Ram Induction throttle set up.
Old 10-08-2012, 11:59 AM
iluv69s iluv69s is offline
Fom what i have seen, from the firewall to the gas pedal, the setup is basically the same as a 6 cyl.setup and it comes out thru the same hole in the firewall. The one difference I have seen is the gas pedal arm on the crossram setup being gusseted and slightly different on the geometry/length of the arm that connects to the cable...(but probably negligible on a sreet car). The assembly manual shows the 6 cyl setup. It is fairly basic. Good luck..and post some pics what your building !!
Old 10-08-2012, 10:34 PM
Thanks all for the info. The linkage is inside the car {6 cylinder} and the cable goes through firewall and hooks into linkage..right?? I will post pictures of what I'm working on. Just had surgery and am a one arm paper hanger for a few more days.
Dave
67 Nova Boy
