Old 10-16-2012, 01:47 AM
wisemanz28 wisemanz28 is offline
Default 1111480 distributor
I have a 480 distributor that has alot of distributor end play ( .70" ). Is it ok to add washers to make the gap smaller ( .20" )?
Old 10-16-2012, 04:14 PM
x77-69z28's Avatar
Default Re: 1111480 distributor
I had mine restored by Jerry m. He has a sun distributor machine, recur vies it, resins it, checks all the spring weights. I believe it was $145. Works great
Old 10-16-2012, 08:59 PM
I wanted to fix it myself but thanks for the advice.
Old 10-17-2012, 09:00 PM
David C. David C. is offline
That's what I do to tighten them up whenever I do a rebuild.
Dave C.
Old 10-21-2012, 03:49 AM
Kurt S Kurt S is offline
Break the tab off a spare hardened washer that's by the distributor gear. Add it and your end play should be good.
Kurt S - CRG
