Posting on multiple sites hoping for a good answer.
Both doors stick out just a little too much at the bottom rear. Right side is worse than left. Front of door sits even with the rocker Both are the original factory doors. Car has never been hit, and no dents were taken out of the doors other than tiny door dings. All original sheet metal except for GM valance and header. Yes, I had both doors off the car at one time to rebuild the hinges. Factory hinges with new bushings. I can't adjust them in at the bottom hinge or the front of the door is too far in and won't line up with the rocker. I can adjust them out at the top hinge and make the back line up fine, but then the fender has to be moved out a corresponding amount at the top and the hood to fender gaps are unacceptable. What am I missing? Are the factory doors just that bad a fit?
