Old 12-09-2012, 09:05 PM
sah62's Avatar
sah62 sah62 is offline
Default 1970 GM 1233464 Metering Valve Disassembly
Thanks to a little help from someone at Brake & Equipment Warehouse in Minneapolis I finally figured out how to disassemble the 1970 1233464 metering valve. I just posted an article describing the process:
https://www.musclecarresearch.com/gm-1233464-autopsy
I'm working on a seal kit so it can be rebuilt. Does anyone know of any other cars that used this valve in addition to the Chevy and Olds applications?
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang Mach 1
1995 Chevrolet Impala SS
2019 Lincoln MKZ 3.0T AWD
Old 12-09-2012, 10:47 PM
TDW TDW is offline
Default Re: 1970 GM 1233464 Metering Valve Disassembly
Nice step-by-step pictures Scott. I'm sure someone will be very glad to see them.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 12-09-2012, 11:20 PM
SS427's Avatar
SS427 SS427 is offline
We restore every valve on every restoration so it would be nice to see some seal kits for these. I have had to rob from Peter to pay Paul for many years and am running out of donor parts.
Rick Nelson
Old 12-10-2012, 02:51 PM
dl7265 dl7265 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: sah62</div><div class="ubbcode-body">Thanks to a little help from someone at Brake &amp; Equipment Warehouse in Minneapolis I finally figured out how to disassemble the 1970 1233464 metering valve. I just posted an article describing the process:
I'm working on a seal kit so it can be rebuilt. Does anyone know of any other cars that used this valve in addition to the Chevy and Olds applications? </div></div>
Buick, I figured all A body GM. Hope you get the kit for '70!I'd be down for a few.
DL
1969 Buick GS Stage 1
1970 GS455 Stage 1 4-speed
Old 12-12-2012, 11:40 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dl7265</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: sah62</div><div class="ubbcode-body">Thanks to a little help from someone at Brake &amp; Equipment Warehouse in Minneapolis I finally figured out how to disassemble the 1970 1233464 metering valve. I just posted an article describing the process:
DL
</div></div>
X2
Old 12-12-2012, 11:42 PM
enio45 enio45 is offline
Scott - i did get that brake seat as we discussed and it worked out great - nice kits you have!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-15-2012, 10:26 AM
sah62's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dl7265</div><div class="ubbcode-body">Buick, I figured all A body GM. Hope you get the kit for '70!I'd be down for a few.</div></div>
I'm working on sourcing the needed parts now. It looks like all of the seals except for the o-ring will need to be custom made. The wire ring (also custom made) has a 4 - 6 week lead time.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: enio45</div><div class="ubbcode-body">Scott - i did get that brake seat as we discussed and it worked out great - nice kits you have!</div></div>
Thanks, Eddie. I ended up buying a bunch myself because I thought it would make the kit more complete.
Scott Hollenbeck
Old 12-15-2012, 05:35 PM
Yes it would, excellent idea
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 12-20-2012, 03:24 AM
BlueSS454's Avatar
BlueSS454 BlueSS454 is offline
Send a message via AIM to BlueSS454
That is a nice write up and description. I have wondered for a long time how the 70 valves come apart. I have taken apart 69 valves, but the 70 ones I have always just cleaned and hoped for the best and have had them work as intended.
Tom Rightler
Vice President, Maryland Chevelle Club
MCC Newsletter Editor
1970 SS 454
1970 SS 454 Convertible
1969 Malibu
