Old 01-06-2013, 11:57 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default 1970 L78 Camaro PROJECT
This is my brother's car. After many years and many attempts to get started on this significantly-sized project, he's decided to let someone else have a go. Classic copper, black interior. Motor is out of ANOTHER 1970 L78 Camaro, ran great when removed. Car is all apart now. Muncie 4-speed (not the original trans). Does have its original 4.10 12-bolt. L78 specific TRIM TAG. Somebody used it as a drag car so the floorpan has seen its share of mega-RPM clutch dumps and tunnel-chopping for Hurst Super Shifter. Rear rails are poorly patched. 1 of only 600 so it deserves to be saved. $21,000
Old 01-07-2013, 12:39 AM
njsteve njsteve is online now
Default Re: 1970 L78 Camaro PROJECT
Nice project car. That will be a beauty when restored.
Just out of curiousity, does it have GM of Canada docs?
Did you ever run the engine's vin by GM of Canada to see if that car is locatable?
Old 01-07-2013, 11:47 AM
Tracker1's Avatar
Thanks Steve. Neither this car nor the car the engine came from were Canadian-sold cars.
Old 01-07-2013, 09:40 PM
69LM1's Avatar
69LM1 69LM1 is offline
Started a thread at NastyZ about your car. They have some questions and it might get some interest your car.
http://www.nastyz28.com/forum/showthread.php?t=255212
RichPern
Rich Pern
69 Camaro COPO "Tin Soldier"
Old 01-08-2013, 11:53 AM
Tracker1's Avatar
Thanks Rich, appreciate it. I am newfzee on that site.
Old 01-08-2013, 12:14 PM
Tracker1's Avatar
Old 03-20-2013, 11:02 PM
Furback Furback is offline
THere was a 1970 L78 car here in Saint John. When I was a kid, the guy had fender flares put on it at a body shop across from my house. It went into a garage for years and came out rotted all to shit. I mean bad. But still had the matching numbers power train in it. A friend of mine scooped it up for $500. before I heard about it. No one knew what it was, until my friend had me check the numbers on it. I could not believe it. The car went to Ontario, probably rebodied by now. Was 4 speed car. Steel wheels with hub caps originally, I think it was brown or copper color new.
1968 Nova SS
1970 Camaro Z28
1987 Buick GN
1975 Trans Am
1972 Blazer
1968 Ford Ranger
1964 Ford short step
1929 Ford Coupe
1931 Ford Coupe
1986 GMC Wrangler 4X4
